1.0a4-Azurit
So I tested installed HAL sensor on the Mow motor and signal is following :
when magnet is on hal, there is 0V :
and out of the hal 2,6V :
Not sure if this short pulses are enough for interrupt counting.
I found also other PCB with other HAL and signal is different :
What's your opinion ?
Thanks
Alex
Attachment: https://forum.ardumower.de/data/media/kunena/attachments/1183/running.jpg/
I would assume that only the last signal will work. The first signal needs pre-processing by some circuit.
"The only source of knowledge is experience." (Albert Einstein)
